By buddylovesfrenchfries - 3 Years Ago
How can i rig a dog and easily use it for iclone8? Please let me know thank you!
By Peter (RL) - 3 Years Ago
Creator Creator 4 and the standalone AccuRig software are designed for bipedal characters so you can't rig four legged animals in those unfortunately.
To be able to use a dog in iClone 8 you will need it to be pre-rigged. Alternatively you can purchase a pack which contains domestic dogs like the one below.
https://www.reallusion.com/contentstore/csproduct.aspx?contentid=AIC320CIENU050120091229001
i have a custom dog i need to rig. where do i rig a dog and can you give me more tips on how i will import a "pre-rigged" dog :)
By Nirwana - 3 Years Ago
How (i.e. in what application) did you create the custom dog? Most 3D programs such as Cinema 4D, Blender, etc. make rigging possible. iClone is only suitable for 2-legged, more or less humanoid characters.
If you don't know how to rig your model and it is a one time only situation, you could possible also have somebody else rig it for you.
By 4u2ges - 3 Years Ago
This is as "easy" as it gets:
By will2power71 - 3 Years Ago
I feel your frustration. This is one of the things I've been requesting since Iclone 6. Accurig is great, but it's only 80% of what we need. iClone is long overdue for a full rigging toolset, including the ability to create controls as well as bones, with spline rigs and IK setups of all types. I mean if they wanted to compromise, then putting a quadruped rig, bird rig, snake rig and set of wings rig would go a long way towards alleviating those frustrations. I really would like to see a full on rigging toolset in iClone.
Okay done. one issue..... How do i import it into iclone8 after i finished rigging it. I tried to do it as a fbx rig but it does not import.. please help
Have you made it in Blender? Before exporting make sure to select only the dog mesh and check "export selected" on FBX export settings panel.
Yes i imported from blender and did what you said. It than imported but as a prop not a rig,
That is correct. iClone only imports iProps, which is normal for animals. You may also import through CC as a Creature.
so what do i do? if i import it and it than has no skeleton how am i suppose to animate him
i agree. It would make everything so awesome. Even having accuRIG have a rig mouth feature would even be amazing.
but how would i rig it? like how can i animate if it imports as props and removes the skeleton
Okay i now understand what you mean. But how do i import animations to the "animal" I Prop. Do i make it in blender? than import it? If yes than how
It has a skeleton. If you go animation tab > Edit Motion Layer, you'd see it. But no one I know animate animals in iClone unless it's a basic animal like a fish. I mean you may pose and do some basic movements, but to create a believable animations you need something better than that. Do the research for rigify in Blender, animate and then import your dog along with animation.
there is no motion to edit
