Full-body motion capture in realtime using HTC VIVE Trackers
https://forum.reallusion.com/Topic543823.aspx
Print Topic | Close Window
By sunnyviewtech - 2 Years Ago
Dollars VIVA launched!
You can now use HTC VIVE Trackers and its compatible hardware to do full-body motion capture with a minimum of six-point tracking in iClone8!
More about Dollars VIVA, https://dollarsmocap.com/viva
By brothertcoleman - Last Year
Hi ,just noticed this,can you tell me what all I would need hardware wise to get good data for Iclone 8.
On Amazon I see the HTC 3 Pack Vive Tracker (3.0)
and also the Vive Ultimate Tracker 3 Pack + Dongle— Full-Body Tracking for VR but on the video I see hand controllers ,what are they called?
Thanks
By sunnyviewtech - Last Year
Hi, the controllers in the video are these,
https://www.amazon.com/Valve-Index-Controllers-PC-Mac/dp/B086DJXXKV
Please note that because the controllers connect to the computer wirelessly through the HMD, if you purchase the controllers without a HMD, you will need two dongles to connect the controllers to the computer.
Dongle,
https://www.amazon.com/Ultimate-Tracker-Dongle-Not-Machine-Specific/dp/B0CP4JB279
Thank you ,So will this work along with the two items you mentioned?
https://a.co/d/cdv25E2
Or is there another one that recommended because I don’t see a head strap for this one?
Thanks
Hi, they will work, but you can also buy some Go Pro straps to make your own
