5.2 Not working with Character creation process (Pipeline) as before.
https://forum.reallusion.com/Topic542612.aspx
Print Topic | Close Window
By Ihms - 2 Years Ago
I'm assuming that Pipeline is not a part of the new 5.2 upgrade.  Character creating as with 4.5 was quite straight forward.  I'm having much difficulty with the creation set-up in 5.2.  most likely I'll be suing 4.5 for my creating characters. Here are some of the issues:
The program crashes often.
Instead of importing my psd file, Cartoon Animator will take me to the program that I use to make the characters in.  So, it doesn't import the characters.
There doesn't seem to be the separate character workspace as in 4.5, which allows to fine tune the character.
I apologize, if I missed the whole new features and how 5.2 works, but I need a little guidance on what I'm not seeing.
Thanks.
By Peter (RL) - 2 Years Ago
Cartoon Animator 5 has all the same features of Cartoon Animator 4 plus adds a number of new features like being able to create Vector SVG characters.
So if you just want to create characters the same way as you did in CTA4 then you can still do so. The same functionality is still there. To understand the problems you are having perhaps you could post a screen capture video showing the issues you are having, or alternatively try to provide the steps you take leading up to the issues you are having.
