how to add color mask to Live link / atuo set up Shader ?
https://forum.reallusion.com/Topic542402.aspx
Print Topic | Close Window
By Jbowdoin - 3 Years Ago
this may be a question for the RI devs
any one know how I can make a color mask for 2 color?
note; in this example I used blue to represent alpha on the mask.
https://forum.reallusion.com/uploads/images/1056f3cb-c3f3-4654-90b0-af11.png
what im looking to do is use the  wright to mark were color A goes
use black to determine were color B goes
and Alpha (blue in the pics) should be ignored and just use the color of the defuse map for the mesh only. How should I change my approach ?
I did see a second Example were you would make a mask with a (RGB) color mask but to do that I would need to lerp the color with the diffuse texture in place of the multiply node
however I can not find the base color tent node to try that
would it be something like this ?
it seems to treat the mask as a defuse map when I try it like that
im at a loss
By StyleMarshal - 3 Years Ago
thanks, looks like I just need to figure out how to o make a Mask Texture to store different kinds of Texture information into the individual R, G, B, and Alpha channels  with gimp?
what I have now is more like a CC3 color ID
were is the node for base col0r tint ?
I canto fallow the video without that
Jbowdoin (10/6/2023)
it's called "constant " (2-4Vector) , right click and type constant or hold the number 2, 3 or 4 (4=+alpha) and click with the mouse into an empty space in the BP.
There are a lot of tutorials around ....
