AccuRIG keeps crashing after i finish the rig,
https://forum.reallusion.com/Topic542306.aspx
Print Topic | Close Window
By buddylovesfrenchfries - 3 Years Ago
After AccuRIG's new update, it crashes every time I try to finish rigging by tapping the finish button. It loads, then crashes. This has happened with every rig I've ever made on here. I even tested it on the already made rigs to see if it's the app's issue and found out that it is indeed the AccuRIG app. The issue started after its update. Please let me know how to fix this or if this is also an issue for you.Also, yes i also restarted my labtop and the issue still occurs .
By Peter (RL) - 3 Years Ago
Hi...
Have you tried the rigging process with one of the sample characters that come with AccuRig (File > Load Sample Character). Does the crashing still occur? If not then it may just be the character you are using that is the problem.
However, if it still crashes with the sample characters, please make sure your system is fully updated and you have latest graphics drivers installed. Then if the problem continues, please contact Support using the link below. They will be able to advise you further.
Hey man i even tried contacting support and there is no place for me to contact for accurig
Apologies for the delay in replying. We have been investigating this problem and can confirm there is an issue with the finalization process which is affecting some users.
We are urgently working on a fix for the problem and hope to have this ready soon. Please do accept our apologies for the inconvenience caused.
Thank you for replying and informing me!
Alright sorry i have one more question. When you all do fix the issue. Will there be a update prompt to accurig telling us to update? And when do you think the issue will be solved cause i schedule youtube videos
buddylovesfrenchfries (10/11/2023)
It depends on how the fix is released. If a temporary hotfix is released  first then I will let you know in this thread with the download link. If a full update is released I will again update in this thread but you should also get a notification the next time you try to launch AccuRig.
Okay thanks... This is super bad for me as i use AccuRIG for my Youtube career :( Hopefully it gets fixed soon.
buddylovesfrenchfries (10/14/2023)
The good news is we have found the problem and are now just running some tests on the new build. If all goes well we hope to have the new version available in the next couple of days.
ITS FIXED THANK YOU!! :)
