By Dan Miller - 2 Years Ago
When I click on Morph Creator it will not open. I've tried with multiple characters and I have restarted iClone. Any ideas what might be causing the problem? Thank you.
By animagic - 2 Years Ago
I don't have a solution, all I can say is that it works for me.
Did you try with a prop to see if Morph Creator opens then?
By 4u2ges - 2 Years Ago
Is it not on a tasks bar either?
animagic (9/30/2023) I don't have a solution, all I can say is that it works for me.
After you suggested it I tried with a prop. Same result.
4u2ges (9/30/2023) Is it not on a tasks bar either?
It's on the task bar. I click it, something begins to launch but it is just a fraction of a second, then nothing. I don't recall, there may be logs that I should be looking at to get a better understanding of the problem.
That means you had a second monitor connected at some point and had Morph Creator at that screen? Windows remember those things. While you select Morph Creator on a task bar hold windows key and hit either left or right arrow key a few times to move in over.
I use three monitors. At times I move iClone from one monitor to the other. I did what you suggested with the Windows Key and left/right arrows. It does not change or reveal anything. Sometimes it may open something on a different monitor but it is easy to see that. In this scenario, I don't see a dialog box anywhere. Its been quite awhile but I'm pretty sure when clicking Morph Creator I should get a popup box that remains visible.
You could have moved it off screens completely. That happens and a trick with Windows+Arrow always works for me (for any window in Windows actually), but it has to be highlighted on a taskbar.
I see, I did give it a try but not working. When I click on the other items like Morph Animator, Face Key, etc, it pops a box right open and on the same screen.
