Morph Slider missing in action.
https://forum.reallusion.com/Topic542111.aspx
Print Topic | Close Window
By mark - 3 Years Ago
I believe this has been mentioned by others but I'll try as well...
Every single time I run CC4 I have to uninstall and reinstall the "Characters" pack. The avatars are there and load but the morph-sliders are always missing in action. Other packs with morph-sliders behave the same, like the Hivewire "Dawn" & "Dusk" packs. The avatars are there  and other components of the pack will be there and load but the morph-sliders are always missing. Once I uninstall and reinstall the packs all is well but as soon as I close the program and reboot CC4 the morph-sliders are missing again...only the slider-morphs.  WHAT AM I DOING...PLEASE?!
https://forum.reallusion.com/uploads/images/1cd4df7e-b762-4213-8da1-fa9f.jpg
By rcsinger29 - 3 Years Ago
CC3 is doing the same thing for me.
Well at least you got a reply from Peter. I got squat. I guess we're the only ones with this issue.   Looks like we'll have to file a Support ticket.
By animagic - 3 Years Ago
Mark, I had some problems with Kevin as well. Since I was part of beta, it seemed that some remnants from older files messed things up. So I actually deleted those files. as uninstalling was not enough. You could try that.
Thanks Job. Filed a Support Ticket yesterday and that dear Rampa came back with a little .bat file ( almost Halloween ya know) that reset the database. All is good so far!
I ran the batch file also but it didnt work for me.
https://forum.reallusion.com/uploads/images/1c16e0ff-c4b8-4d58-abdd-f3de.png
By gordryd - 3 Years Ago
I have the same problem after update to 4.32 -- RL needs to fix this, not patch on individual user basis...
EDIT:  I loaded a different character (from TokoMotion) and sliders seemed to load OK.  Then I re-loaded Kevin and all the sliders were there...seems to be working OK now?  Maybe it just needed to re-fresh it's database.
By Rampa - 3 Years Ago
If your sliders are not appearing at all, please select "Refresh Sliders" from the Help menu.
My issue was the Headshop Plugin Trial.
So the problem was that I had downloaded the headshot plugin trial version and it had expired. For some reason, the disabling features of the expired plugin were overriding installed content sliders. Upon uninstalling the Headshop plugin, all of my morphs came back.
