HailDuong (6/23/2010)
Yeah, I am able to run in Pixel Shader mode with all other graphical options turned on. :D
I checked my graphic card settings but i could not find any option for anti aliasing. All of my driver are updated...
My System: Compaq Presario CQ40-105TU Notebook with 1GB RAM, Intel Pentium Dual CPU T3200 @ 2.00Hz. Win 7 Ultimate 32 Bit. Intel Graphic. Thank you! :(Thanks for supplying more information. It would certainly seem the Intel Graphics are the most likely cause of the anit-aliasing problem. While later models of Intel Graphics do support Pixel Shading they are not the best for 3D work and iClone will disable the anti-aliasing option if it isn't found to be fully supported.
If you would like further assistance, you can send a Support request using the link below. Technical Support will look at your DirectX log to see if your system can support this feature.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks.
