Missing Teeth Morphs
https://forum.reallusion.com/Topic541560.aspx
Print Topic | Close Window
By ramart313 - 3 Years Ago
Hello, recently I was working on a model where I had to create fangs, like a vampire,
in his mouth.  I had done that in the past with teeth morphs, but for some reason I cannot
find those teeth morphs anymore. I belive I just used the CC Teeth for  this.
 I also recently had to reinstalled Character Creator 7 and I am note sure
if that had anything to do with it.  I remember being able to morph invidual teeth which was
very helpful.  Maybe I am doing something wrong or looking in the wrong menu?
Any help would be greatly appreciated.
Thank you
By thebiz.movies - 3 Years Ago
Check this out and see if its any help...
https://www.youtube.com/watch?v=WodXVUcNR5o
Thank you for your reply!
The problem is that, I already took that turorial and it was very helpful.
Tha problem is that when I choose CC_Base_Teeth, under the Morphs menu,
I only get 3 morphs to choose from instead of 50 other morphs I believe the
video shows!  It used to show themall  but now there is only three that appear.
I'm running CC4 and the CC3+ Caleb Character has all the specified tooth morphs referenced in the video (and many many more).  Sorry I cant be of more help...
By 4u2ges - 3 Years Ago
CC_Base_Teeth only has 3 morphs.
But all other morphs are placed into sub-folders in the morphs tree.
To view all morphs under the CC_Base_Teeth you have to:
in CC3 check "Show all sub items" box at the bottom.
in CC4 click on the sub-folders like icon at the bottom.
Otherwise just click on respective sub-folder under CC_Base_Teeth to vew more morphs.
Those canine morphs you are looking for are under "Details"
Thank you very much for answering.
When you mentioned that the teeth morphs are under the morp tree.
Is it at the bottom of the Morphs menu under the Actor Parts?
Its just because under there I just get three Morphs.
I included a picture of where I am looking under.
If I am wrong, could you clarify again where the Teeth Morphs are supposed
to be?
Thank youhttps://forum.reallusion.com/uploads/images/82512553-654b-4722-99cf-f061.jpghttps://forum.reallusion.com/uploads/images/e2dc843e-e3d5-4992-9f4c-0dff.jpg
to be?
to be?
I got 3 more sub-folders under CC Teeth. But apparently 2 of them are from Ultimate pack ("Detail", "Adjust") and another one is from Headshot.
I bought them years ago so did not pay attention. Maybe you need to reinstall an Ultimate pack (former CC Essentials pack I believe) since you said you had them.
