No delete mesh button ?
Home
Character Creator 4
General
https://forum.reallusion.com/Topic539640.aspx
Print Topic
Close Window
By K_Digital
3 Years Ago
Hello, this manual says "Click Delete Mesh", but there is no Delete Mesh Button in CC4. Bug or i just dont see it ?
https://manual.reallusion.com/Character-Creator-4/Content/ENU/4.0/09-Editing-Meshes/Deleting-Mesh-Faces.htm
An Earlier Version of CC4 seemed to have this button
By 4u2ges
3 Years Ago
It only works on accessories. Check this ticket and RL reply:
https://www.reallusion.com/FeedBackTracker/Issue/Edit-Mesh-mode-does-not-allow-to-delete-faces-from-Cloth-or-Hair
So if it's a cloth you have to convert it to accessory, trim, and convert back to cloth.
And RL fixed the issue with weights converting back to cloth:
https://www.reallusion.com/FeedBackTracker/Issue/Converting-cloth-to-accessory-trimming-and-converting-back-to-cloth-does-not-work-as-expected
By K_Digital
3 Years Ago
Hi
and thanks for answering.
So, this is not even possible with Hair ect. following your links. Looks like they havent updated the manual yet.
I was going to edit some hair, i guess i can go through the Scuplt brush instead and hide some meshes.
By 4u2ges
3 Years Ago
No, you still can. Just convert hair to accessory, edit/delete faces/elements, convert back to hair.
