CC4 Running SUPER Slow
https://forum.reallusion.com/Topic539474.aspx
Print Topic | Close Window
By cepheistudios - 3 Years Ago
All of a sudden - just within the past 2 days - my Character Creator 4 is running ULTRA slow. Not sure why. I cleaned up my cache, I ran every computer scan I can think of, I optimized the computer so it runs faster - but still nothing. I am running Task Manager in the background and everything looks FINE. I'm only using up 18% of my memory, and only 34% of disk space and that's WITH Google Chrome open. So CC4 isn't using up an unusual amount of resources - NOTHING is. What's WEIRD is Iclone 8 runs just fine. Smooth as silk. I just don't get it. It isn't just the specific project file I'm opening either - it happens with 2 sepearte project files I've tried and each one has entirely different assets loading. Is this happening to anyone else??
By Peter (RL) - 3 Years Ago
You mention problems with two existing projects, but what about if you start a new project and begin working on a character? Is this running slow or is everything normal?
Also are iClone 8 and CC4 installed on the same hard drive?
Same. All CC4 runs really slow. Customer Support reached out to me and I'm going to try their fix when I get home. I did uninstall and reinstall the program already, but there was a setp I missed. Hopefully that works. Other than running abysmally slow, the program works - it just has to be something happening when it loads.
The answer was cleaning out the Temp files. When I loaded CC4 I put the Temp files for the program on an external SSD so they wouldn't clog up my computer. Then I conveniently FORGOT that I put them there. When I cleared those out everything worked fine. Customer Support did a good job. The Temp files should really be cleared out quarterly to prevent this sort of thing.
