Program changing skin color automatically
https://forum.reallusion.com/Topic539307.aspx
Print Topic | Close Window
By zoomyjs - 3 Years Ago
When I go into appearance, Makeup then activate editor and change the color of the eyelashes it changes the whole skin color for some reason once I exit the "activate editor". Except for the head, so everything looks rediculous. Is the program broken?
By Peter (RL) - 3 Years Ago
Hi...
I have had a test and can't reproduce the problem myself but it might be I'm using a different workflow.
Please can you let us know the exact steps you take leading up to when the issue occurs. Also do check the process with a different character in case the issue is with a particular character.
