I've come across an issue involving the CC Pipeline Addon and Blender. Specifically, the expression morph gets broken when I import a CC4 character to Blender, and then import it back to CC4.
At first, I thought this was a problem related to the pipeline plugin. However, I've realized the issue can easily be reproduced using only CC4. This suggests the problem lies within CC4 itself.
It's worth noting that I've been using this workflow since the days of CC3. Interestingly, this problem never occurred with CC3.
The Environment Settings:
- CC4: Version 4.12 and 4.3
- Windows 10
Below, I've outlined the procedure to reproduce this issue. Could you please check if others are experiencing the same problem?
1. Load any CC4 default character
2. Export FBX (the setting is what I usually use)
3. When load exported FBX again, this dialog appears
4. And the facial expression is btoken
