Character Creator 4 Import Animations from ActorCore Issues
https://forum.reallusion.com/Topic538610.aspx
Print Topic | Close Window
By luciandm - 3 Years Ago
Hello everyone, I have a lot of trouble importing animations to a character in CC4.
The character is rigged with Accurig and added a few extra bones in other program. Then Reimported in CC4 and used characterization. (attached)
Firstly, if I import Mixamo animations in CC4 on my rig they work perfectly (in Unity too)
But the ActorCore animations that I download, they work well if I import them to Unity on the same rig. BUT NOT in CC4. The animation is imported badly.
Also when I download the animation from ActorCore in the templates I use Unity because if I select IClone8/CC4 it DOESNT do anything.
Does anyone have issues with the animations in ActorCore?
Is weird that Mixamo animations work and not ActorCore which uses a close naming convention.
https://forum.reallusion.com/uploads/images/b120c8df-55c2-4718-9eec-6b8e.png
By Peter (RL) - 3 Years Ago
luciandm (7/2/2023)
Hi...
If you want to use the ActorCore motion in CC4 or iClone 8 then you should choose that option rather than the Unity pre-set.
So when you select the iClone 8/Character Creator 4 download option in ActorCore your animation will be available in your Content Manager in CC4. If you have iClone 8 or CC4 open when you choose to download the motion in ActorCore you should see a pop-up appear asking if you want to install the new content. Once installed in Content Manager the ActorCore motion should work flawlessly with any Standard or Humanoid character.
