2D to 3D
https://forum.reallusion.com/Topic538410.aspx
Print Topic | Close Window
By spericus - 3 Years Ago
Hello,
I would like to use a picture of an object and use it in Cartoon Animator, and then interact with it. The problem is that is not 3D (for example a table where i cannot put a person sitting on it).
My question is: how can i transform the picture into a 3d prop and then use it on cartoon animator?-
Thanks a lot.
By Peter (RL) - 3 Years Ago
Cartoon Animator only uses 2D. It does not use 3D characters or props.
The benefits of using 2D is that any photo or drawing can easily be made a character or prop inside Cartoon Animator.
So even if you convert your 2D image to 3D you will still need to convert it back into a 2D image to be able to use it in Cartoon Animator.
So the best way to resolve the issue is to try and find a photo or drawing of the prop you want to use at the right angle. So for example a chair that is visible at the angle you want so your character can be positioned so that it looks like it is sitting on the chair as shown below.
https://forum.reallusion.com/uploads/images/d911882e-49ee-4e3f-99c2-a30d.jpg
