By jeff.davies - 3 Years Ago
I have several characters that I have set to Auto On Path with Move set to 100% (ie no idle). I notice that they will all pause for about a half ssecond randomly on the path (though when animating 2 characters at once, the both pause at the exact same time), I believe they usuaally pause near one of the path markers. Is there a setting I need to use to eliminate this?
Also, when using Auto on path, when they reach the end of the path, they automatically turn around and walk back to the beginning. Can I tell MD to stop the animation at the end of the path? Thank in advance!
I think I may have found the solution. It appears that not only do you need to set the Idle/Move ratio to 100% Move, but also set the min and max values for the Idle Time Range to 0% (or 1.0 each)
