normal texture exporting issue
https://forum.reallusion.com/Topic537741.aspx
Print Topic | Close Window
By _RESERVED_.ca - 3 Years Ago
Hi, I am always facing normal problem with character creator export. It shows hard seams in edges of UV and some weird black spots on the model as well.
I found the same issue here, https://forum.reallusion.com/323008/Character-Creator-to-Max-Normal-Map-Seam-Problem  , but it did not fix my problem. I have tried loading the model, textures in max, maya, all shows the same problems. Is this a software bug or only me facing this issue? The only way we fix it is to make a new normal texture in zbrush.
https://forum.reallusion.com/uploads/images/7ff8a207-c358-4cb8-801c-43c9.png
