Can't export fbx without UDIM
https://forum.reallusion.com/Topic535100.aspx
Print Topic | Close Window
By vinitius - 3 Years Ago
Hi,
I need to export a fbx to use it in Unity without the UDIM UV Layout.
There is a checkbox in the export settings to turn it off, but it doesn´t seem to work. Even when UDIM is unchecked, UDIM layout is still present.
Is this a bug or am I completely misunderstanding this checkbox?
Anyone with the same issue here?
Using Character Creator 4.21
By NexVice - 3 Years Ago
Same issue here. I haven't tested in 4.22 or 4.23 though. Hopefully that gets fixed. Because it makes it impossible to edit UV Maps in Blender.
By Peter (RL) - 3 Years Ago
Thank you for the feedback. If you believe there is a bug or issue with the software, please remember to report it in the Feedback Tracker. The tracker is monitored directly by the product teams who will investigate the issue and give you a status update. The tracker is the best way to get issues looked into and fixed in a future update.
To use the Feedback Tracker, please click the link below. Thank you.
https://www.reallusion.com/FeedBackTracker/product/Character-Creator-4
By gamehorizongr - 2 Years Ago
Have this been fixed or is there any solutions i have the same issues, exporting as usual without udims is not working
By vinitius - 2 Years Ago
Hey, guys. I don't know what kind of issues do you have because of this "bug", so this information my be useless for you, but when I neded to edit the UVs to work as needed in Unity, I just laid the UVs on top of each other in Blender using snapping to the grid (see the picture).
I'm exporting from CC4 using the remesher with merged materials now. Body textures are combined to one map, so no UDIM feature there.
https://forum.reallusion.com/uploads/images/a4ab6af9-8028-4608-96e5-d5c2.jpg
By Rampa - 2 Years Ago
Please check your FBX settings. You can choose UDIM or regular flavor. :)
