Importing a set/prop from DAZ
https://forum.reallusion.com/Topic533886.aspx
Print Topic | Close Window
By COLINMAC2 - 3 Years Ago
This is really close to breaking me, and YES I've been through the manual on importing props. Now when I try to import a set as a prop, all that comes up is one bright pixel. Nothing else. I've tried three times, and that's all I get. I'm exporting the whole product file, so it can't be that.
I was able to import ONE scene only, and that one causes CC to crash every time I try to render.
I feel like I'm going out of my MIND here! I know you people have helped me, obviously enough to get sick of me, but PLEASE help me one more time?
By jeffkirkland - 3 Years Ago
Can't help much other than to say it works fine for me. I'd suggest hunting up a tutorial and checking that your DAZ Studio FBX export settings are right.
You might also try using Transformer instead of just loading the prop as an FBX. Save the set with a DAZ character in the scene. Transformer will treat the props as an accessory. Once it's in iClone delete the character and save the prop.
By animagic - 3 Years Ago
I think if you gave details what you are trying to import, you may get more specific advise. Systems specs are also relevant.
DAZ objects are sometimes very high poly so if it's in the millions with high-res textures, CC may choke on that.
