"failed to load the file. Fbx key is invalid"
https://forum.reallusion.com/Topic533529.aspx
Print Topic | Close Window
By jerome.dipietro - 3 Years Ago
I'm starting to get a few instances of "failed to load the file. Fbx key is invalid" when trying to reimport into CC4 using the Blender Pipeline plug-in (and Blender add-on)
Usually I just have to re-export and redo my work in Blender then try again, and it then seems to work but I'm wondering... is there something obvious that could be causing this? It's a bit of a pain.
ps. I should perhaps say that yes, an FBX key is definetely being generated on export and is kept in the same folder as my FBX file. (the FBX I load into Blender and then save over when Exporting using the Blender CC add-on)
By aitsam.ahmad - 2 Years Ago
the cost of these software and next to non existing support when it comes to these things is quite painful tbh. i have been facing same problem.
first there was no straight foward way of button to export fbx key. finally resolved it by a user to export t pose as fbx but then whenever i try to import the fbx back it say fbx key is invalid and even though i just exported and have not even editing the fbx.
By Peter (RL) - 2 Years Ago
An fbxkey should be generated every time you select File > Export > FBX > Clothed Character.
However, if you find the key isn't being generated, just close down CC4 and restart. This normally resolves the problem.
