Import from maya into iclone as a character
https://forum.reallusion.com/Topic532634.aspx
Print Topic | Close Window
By bryan_213738 - 3 Years Ago
We have a character created in maya, and would like to use it with the facial capture that iClone 8 uses (trial versions only, we don't know if this is the direction we want to go yet).
It's already skinned to the skeleton we wish to use, it has blendshapes that are named the same as the blendshapes when a character is exported from iClone 8, we just want to see the captures and tests on our character.
I haven't been able to find anything on this topic and a basic import only imports the fbx export as a prop.
By jeffkirkland - 3 Years Ago
You need to be looking at Character Creator and AutoRIG for importing and setting up your character for use in iClone.
https://www.reallusion.com/character-creator/
By Rampa - 3 Years Ago
These are the tutorials for retargeting the skeleton and assigning the blendshapes in CC4.
https://courses.reallusion.com/home/character-creator/characterize
Thank you! quick question... supposed I don't have all the facial blendshapes that iClone has on their characters, will what I do have still map and hook up?
Yes. You can just assign the ones you have. You will have limited facial expression, but the rig will drive them still.
By gametrailerproductions - 3 Years Ago
Hello! I'm looking for some help getting a Maya-rigged character into Character Creator. I don't know Maya that well. I'm a C4d User. Can't seem to get this to work :(. I got the bones to work in the body but not in the face. Happy to pay for your time if you are interested in taking this on!
Thanks for your time!
Brian Patience
brian@levelupcreative.net
