Cookies (FaceIt+IC8+CC4+Noitom+Rokoko Mocap Test)
https://forum.reallusion.com/Topic531896.aspx
Print Topic | Close Window
By zimtower009 - 3 Years Ago
https://www.youtube.com/watch?v=Sxd2YVUabmQ
I asked AI to write a monologue about cookies.
By AutoDidact - 3 Years Ago
You used All of these modern character animation tools
yet you failed to use the edit motion layer feature of iclone to fix the hands penetrating the body.
By Kelleytoons - 3 Years Ago
Yeah, those hand could be SO easily fixed.
If the OP was using a PN suit (he says "Noitom+ Rokoko" so I don't know exactly what tools he's using but the advice will apply to almost any mocap) you need to be sure to keep your arms AWAY from your body when performing.  This is a very rookie mistake a lot of mocap folks make.
You can fix it in post - just take about 20 seconds to edit the motion layer at the START of the motion, select both shoulders, and rotate out slightly.  But it's VERY sloppy not to do this - takes so little time to do it right.
