Accurig runs into error on characterization
https://forum.reallusion.com/Topic531827.aspx
Print Topic | Close Window
By jake_696875 - 3 Years Ago
Hi! Whenever I go to make the final rig for my character it errors out on characterization. I tested the program with a sample model and it worked fine. The model that is running into issues is made in CC4 so I am unsure why there is an error. Any ideas for why it breaks at this stage?
By Peter (RL) - 3 Years Ago
Hi...
I'm a little unclear why you are trying to re-rig a CC4 character that is already rigged. Can you explain your workflow in a little more detail. Also, if you have Character Creator 4 are you using the advanced version of AccuRig included in CC4 or are you using the basic standalone version? If the latter have you tried the process in CC4 to see if you get the same error?
