Hair Styles and where to get them
https://forum.reallusion.com/Topic531728.aspx
Print Topic | Close Window
By Tosyk - 2 Years Ago
HI,
I purchased a bundle including cc4 and Hair Builder, hoping I can build various hair types and styles, vintage 1920-1940 styles in particular. few days passed and I still can't find how to build various hairs, especially for males. So what I see right now in my items for males:
- default and free hairstyles (Short blowback and classic short)
- 2 presets in Hair Builder (both samurai knot)
and that's it.
So I wonder where I can find this magical Hair Builder to build my hairstyles?
Here are examples of hairstyles I want to build:
https://3.bp.blogspot.com/-iGIdSnkQlgc/VrQZeyrWHeI/AAAAAAAAPRk/YtQ8CM0rVqc/s640/Men%2527s%2BHairstyles%2Bin%2Bthe%2BPast%2B%252816%2529.jpgPin on Fotografía documentalhttps://i.pinimg.com/564x/f3/a0/af/f3a0afd542658fb724cbcddc93c1b15e.jpg
By Peter (RL) - 2 Years Ago
Hi...
To have access to the contents of Hair Builder you will need to install it first. So in Content Manager just select Template > Pack > All and then search for Hair Builder (see below). Once the pack is displayed just double click the thumbnail to install it. To get more information on Hair Builder and to see what is included just visit the product page HERE.
That said, the Hair Builder may not be the answer to your needs as it is primarily for creating female hairstyles. To see a larger selection of hairstyles for men, please click the link HERE.
https://forum.reallusion.com/uploads/images/6f7e0f4d-30fc-4efb-be2d-ad00.jpg
Thank you, that's exactly what I found when I installed Hair Builder. You confirmed my concerns about the female focused templates of HB.
How I can add more hairstyles or haircuts? Create in another program and import into cc4? How reallusion does it? There's also a guy (https://www.reallusion.com/ContentStore/Pack/classic-mens-hairstyles) but he's not the part of the company I think, so he managed to do this somehow.
In general, it's disappointing. I thought for nearly 800 buck I will get what I need with the Hair Builder, but it turned to be just a Combinator of predefined meshes.
By gordryd - 2 Years Ago
Also look at this pack:  Hair Studio
Might be closer to what you are after.
gordryd (1/29/2023)
Thank you. Will it work with hair builder, morphs? Does it compatible with hairsmart system? can I use it with my cc3+ characters?
I like it has many shapes, but the hair material quality not very close to Trendy Male hairstyles packs. Does it allow changing material to be the same or similar quality?
https://www.reallusion.com/contentstore/image/cc/ACC300CIENU010820211224001/PM_ACC300CIENU010820211224001_11.pnghttps://www.reallusion.com/contentstore/image/cc/CCB0000IENU000020220418001/P_CCB0000IENU00002022041800120220418091132706.jpg
By Sophus - 2 Years Ago
This might not be helpful for you, but you could check out the Artstation store for Male Hair Cards. I personally think these are the most affordable high quality hair assets.
The problem is, you probably need additional knowledge in other 3D applications like Blender to use them to their fullest potential.
If you don't want to use other tools except Character Creator these assets might not be the right choice for you.
You also may need to create textures and shaders, which a tool like CGPal Fibershop can help you to do faster.
But at least you don't need to model the hair cards from scratch if you use the assets from Artstation.
If you want to model your own hair cards from scratch a Blender add-on like Hair Tool can save you a lot of time. But it's still work that needs time.
Sophus (1/29/2023)
thank you for the reply. So you're saying if I have hairs model in obj format I can easily put it into cc4 and make it look like this, I mean the hair material and texture quality not the shape:
By ToKoMotion - 2 Years Ago
Tosyk (1/29/2023)
gordryd (1/29/2023)
Thank you very much for mentioning HairStudio here - appreciate it a lot :). Regarding your questions:
HairStudio hair assets do not include morphs (yet). I added various hair elements in the pack, which can be further adjusted via Transform, Rotate, Scale or the Edit Mesh feature in CC3 to find your desired style. HairStudio is also based on the SmartHair Material feature, but you can not use Hair Builder materials. I'm constantly working on improvements for the HairStudio materials and some new (free) updates will be available soon.
Hope that helps and feel free to let me know if you have any additional questions.
Best Regards,
Tobias
Tosyk (1/30/2023)
No,  I said the opposite. You don't need to create the obj hair cards yourself but you likely need to modify or make textures and shaders to fit Reallusion shader system and you likely need a 3D modelling application with more powerful tools then Character Creator to fit the objs to your character. That's why it might not be for you if you prefer an easy load-asset-and-it's-done-way of doing these things. On the other hand, the selection of hair styles on Artstation is much, much larger then in the Reallusion store and they don't have the giant numbers of polygons you'll find in hair styles from DAZ/Poser stores.
By greenwilliesjrsss - 2 Years Ago
You can make your own hairstyles in Blender. Using the built in tools for free.
Or you can buy various products that make it a little bit more streamlined for a premium $$
I recommend just watching tutorials and not buying the premium products for hair in Blender. As i purchased one of those and later on realized that it was completely unnecessary. But it doesn't hurt to look at the video in order to see what you can eventually learn to do in Blender for hair
Though I haven't tried to export those to CC4 from Blender as I'm using the Blender hair system for UE5 export. You'll have to ask someone else about bringing it to CC4.
@ToKoMotion, thank you. Your add-on looks fascinating, but I'm afraid I need a better material quality atm. I will keep an eye on the updates from your page tho ;0
@Sophus, I understand what you're saying, but it seems you missed what I meant :) I asked if I have hair model can I put it into cc4? And if "yes" is there a tutorial on how to do that? Also, when you mentioned "hair models on artstaion" I go there and purchased a pretty cool pack. So I was thinking if I will be able to put this pack objs into cc4?
@greenwilliesjrsss, thank you for the heads-up on the blender add-on. I didn't know it has built-in feature to build hairs. I need to look at it closely.
There are multiple workflows for making hair in blender. Be sure that you do your research. For example there is an "old" particle system. And then there is also a "new" curves system that is more modular and uses procedural geometry nodes. Both are very powerful and legitimate methods of making hair. But as I said, be sure to spend at least a couple of hours on researching the difference between the two.
By michaelrbarton - 2 Years Ago
You can convert CC4 Camila hair as an OBJ and send to various third party 3D programs.
If you bring it back into CC4, I know you can use the edited OBJ hair as an Accessory in IC8 and CC4.
I don't know if you can convert back to ihair.
If you try and export purchased hair or other items from Content Store and The Marketplace, you will have to buy a
license to use in third party apps. Purchased items from Content Store and The Marketplace are
free between IC and CC.
 You can take any OBJ and FBX hair and import into CC4 as an Accessory.
I only have IC7 and CC3 and CC4. I exported Camila's hair as an OBJ, and imported
it into IC7 (if you have 3DXchange) as an Accessory.
CC3 lets you import OBJ and FBX as Accessories or Props.
I hope this helps.
Here is a good video that gets to the point in a short time:
https://www.youtube.com/watch?v=HF-eIAy2G8U
I was just trying to help, and it seems you dissed me for no reason.
I guess I won't help anymore.
By K_Digital - 2 Years Ago
I stepped into the same trap, "Hair Builder" and "Unlimited Hairstyles" suggests a Hairbuilder for Unlimited Hairstyles and not a Hair Builder for Unlimited Female Haistyles.
Kind of misleading description. In my opinion RL should offer a Hair Builder which either includes Male and Female Hair Parts or offer Builders for Male and Female sperately,
clearly marked as Male / Female.
Another slight joke is that RL sales a Hair Builder - Beard Combo. Dont tell me woman wear beards at RL. ;-) ;-) ;-)
By stevensonewan - 2 Years Ago
Thanks for your question. I couldn't agree with you more. I started learning Headshot and CC4 just a few months back and decided to do an animation on the Oasis brothers Liam and Noel Gallagher. Just as a fun way to learn. And there is no way any of the styles on the content store are suitable. I even tried Auto mode (low res) but that hair is just for background people.
If you have found any more male hair content then please let me know, or a way of easily creating some basic styles.
