AccuRig ERASING UVs on export
https://forum.reallusion.com/Topic530679.aspx
Print Topic | Close Window
By fableblackgames - 2 Years Ago
Exactly what the title says
Ive already textured my character beforehand, and bringing the fbx into accurig then exporting the final result always erases all UVs.
I've tried all combinations of exporting for Maya/Unreal and checking "embed textures" button and even setting up the textures in maya beforehand
By Peter (RL) - 2 Years Ago
Hi...
If you believe this is an issue with AccuRig (rather than the model itself), please can you report it in the Feedback Tracker and the ActorCore team will investigate. If you can supply the model you are using that will be even better and should allow them to find the cause of the issue quickly.
To use the Feedback Tracker, please click the link below.
Thanks.
