By snolan - 2 Years Ago
I've saved out the marker data out to the.ini file and thought these XYZ values would translate over into my DCC but that doesn't seem to be the case.
After I've exported out my FBX from Accrig I thought the marker data would line up with the exported skeleton however there's quite a delta between them.
Ideal work flow would be to be able to set up my markers on my character in my DCC, generate the ini file and use that in Accurig.
Any insight would be appreciated!
