By Da_Drood - 3 Years Ago
Since i was eager to be able to create my own SVG characters to use in CTA5 and I found a great offer on the Affinity Designer 2 website, i decided to buy the software, but i immediately found an issue. I'm struggling to understand how to connect CTA5 with Affinity Designer 2 (since it should be among the compatible SVG Editor's list, judging from the preferences panel in CTA5), since the installation for AD2 is not customizable and i'm using Windows 11. This had the software being installed in a super protected folder (even by user with adminitrator priviledges) which is absolutely ridiculous. This way i basically can't connect the two softwares to work in pipeline. I sent an email already to Affinity Serif development team to ask either for a solution or a refund, but obviouly i would hope for a solution since it seems a very good software. Anyone else in the same situation struggling like me and maybe found a solution already that might help me? Thanks ever so much to whoever will be so kind.
EDIT: It seems like Serif (Affinity devs) are working on MSI installers that will hopefully sort out this issue. :/
By Famekrafts - 2 Years Ago
Go back to Win 10. Use win 11 after mid of 2023. I have found on youtube videos that Windows 11 has a big problem with many design software. Some work, others crash, and others give problems like the one you having.
They can be resolved with a lot of tricks and tips if you search online, but imagine that for some reason you have to format your windows in the mid of using these software, then you will have to go through the whole headache of installing and fixing these problems all over again. Better use Windows 10, till all the major software has fixed their updates and Win 11 itself is patched up in the next six months to give a more stable environment for all designers.
For a person like me who uses all 2D and 3D software, it is a big no for 11. Moreover, my system is so old I cannot even install Win 11. Happy with my Win 10.
