Edit motion layer - when using reach target on hands I cannot motion control head??
https://forum.reallusion.com/Topic529084.aspx
Print Topic | Close Window
By gorg222 - 4 Years Ago
As title says. I have reach target for both hands and try to move head it's not allowed. This doesn't make any sense.
There is that nasty message about "spring" is enabled so I should turn spring off. There is even NO spring.. but I guess it means reach targets on hands.
Often using iClone I'm confused if I see bug or feature. :-)
One solution could be maybe to move my reach target somewhere else in timeline. Do my changes. And then try to move it back as before.. But this is stupid.
I've already did this reach target move, when I wanted to do Motion correction for feet. For some strange reason it wanted to delete my reach targets for hands.
Then i realised I can turn checkbox "Delete previous reach targets" and it seemed to work. But I was doing some tweeks.. and for unknown reason this checkbox became "gray" with unchangeable __ON__ value.
So in the end I had to move those reach target of hands somewhere else
By animagic - 4 Years Ago
The Spring error message can safely be ignored (there is a setting under Preference to not show messages like that). Even old-timers like me don't know what it refers to...:unsure:
The only reason I can think of why you can't move the head is that you have Reach Target enabled for the head. There should then be a dummy Reach Target object for the head to which the head is linked.
