How to make sure that layers in SVG gets imported to CTA 5
https://forum.reallusion.com/Topic528974.aspx
Print Topic | Close Window
By andreas.hagglund - 4 Years Ago
Hi,
I am super new to CTA, and have probably made a stupid mistake somewhere.
I can't get the import SVG to work though.
I have an image in inkscape where I have grouped the parts into various sub-layers, ie head, left arm, right arm etc.
All sub-layers are under a super-layer called character.
When I import it to CTA all layers are gone!! All I get is root.
It does not matter if I save the svg as an inkscape-svg or as a plain svg.
Can someone please help me by letting me know if there is a setting or something I have missed to make sure CTA is detecting the different layers.
In all video tutorials it just seem to work...
Kind regards,
Andreas
Never mind this question - I figured it out myself, but I don't know how to delete the question...
CTA 5 only recognizes the top layers, so it is not possible to import a hierarchy of layers.
Somehow I get the opposite understanding from watching various tutorials online.
By grinnbear - 4 Years Ago
I've been trying to get a character into CTA5 today and one thing I can tell you is you HAVE to use the layer naming conventions. You have to have two separate layer groups, one for bones & one for images. Each bone layer has to be connected properly to each other & the ONLY thing that can be in your different groups, head, arm, etc. are paths. I'm taking Mark's 2D 101 class ( it's great!) and I am a bit confused. Tomorrow I am going back to the class and ask what I did wrong.
By Famekrafts - 4 Years Ago
Yes, check out the end of the - Create Your Animated Series Fast in Cartoon Animator 5. I was having a similar problem with Illustrator, he made a video for me and all the students
By shotymac - 3 Years Ago
I know this question is old and may have been solved... but in case anyone else stumbles across this thread with the same issue.
The way to import an SVG with layers intact is a bit different than the documentation shown in the CTA 5 help. The CTA 5 help shows that the layers should be under a layer 1 group folder, directly followed by a named group. Following these instructions resulted in only a single root layer. Instead, bring all body part groups to the top, and make sure all layers are uniquely named, with no duplicate layer names, or the layers will not be carried over when brought into CTA 5.
