Norton Anti Virus blocks RL Hub installs...
https://forum.reallusion.com/Topic528850.aspx
Print Topic | Close Window
By gordryd - 4 Years Ago
...even with everything in NAV disabled.  Due to the naming conventions used by the Hub (every install seems to get a new random number filename assigned) there is no way to put the install files in a "Do Not Block" list in NAV.  This has been happening for at least he last 3-4 updates (and I have seen elsewhere on the Forum that I am not the only one with this problem).  It had worked fine up until that time, so either something changed in the Hub process, or something changed in NAV.  Very annoying not to be able to install updates...
