GOZ working on all except this one CC4 model
https://forum.reallusion.com/Topic528699.aspx
Print Topic | Close Window
By Hunz - 4 Years Ago
Hello,
It's a strange one.  I've been using CC4 and the GOZ workflow flawlessly.  This particular character is shorter than the standard and I've been using the binding pose on the CC3+ for all the roundtrips so that my substance painter workflow and marvelous designer models are all in the same pose.
This workflow doesn't work.
1.Loaded my CC3+ BASE adjusted character in CC4
2. GOZ it to zbrush
3. GOZ it to CC4
4. CMD window pops up to push it but the IMPORT window in CC4 doesn't appear.
I've tried the following;
1. Loaded my CC3+ BASE adjusted character in CC4
2. GOZ it to zbrush
3. Reset the the character to default CC3+ BASE
4. CMD window pops up to push it and IMPORT window in CC4 appears.
(this is not very ideal as all the bones need to be readjusted and the whole thing is broken)
2. GOZ using both Default T and A
3. GOZ it to CC4
Any help is appreciated.  If the outcome is short characters or certain morphs are off limits using this roundtrip is there a list somewhere?
Thank you!
By luke (RL) - 3 Years Ago
Hi, Hunz
Are you still having this issue?
We've already fixed some GoZ-related issues in the latest version. We just want to confirm whether the issue you mentioned still persists or not
thanks,
