By rickygai - 4 Years Ago
Reallusion CC4/Character Creator 4 Version 4.12.1125.1
Hi,
I created a character with Denim_shorts overlapping the Underwear_Bottoms item as shown below.
1. How to scale the Denim_shorts content item ? 2. How to modify Denim_shorts vertices so it covers the white patches areas of Underwear_Bottoms without adjusting the character glute ?
Please advise.
Found the solution HERE, the method used was to paint over and covers the leaked patches or holes on cloth.
By mark - 4 Years Ago
And don't forget to first try...Tessellation (which smooths and slightly increases the mesh size of the chosen item) for the clothing in the Scene List. Then Subdivision (which smooths and slightly decreases the size of the mesh) of the chosen item. Then under the Modify Tab there is Conform/Calculate Collision of the clothing item, also there is an Increase Size feature under Conform and then under Cloth Layer Settings you can Auto Hide mesh under the chosen item. Also you can alter the items mesh with the Edit Mesh feature by pushing or pulling or moving the point and polys. You shouldn't really have to paint out anything but if so that would be a last resort in most cases.
By toystorylab - 4 Years Ago
In cases like this, don't use underwear you won't see anyway... No need for panties! :D
...what TSL said !!! :P
By animagic - 4 Years Ago
Also, apply Transfer Weights which is the first step to help clothes fit. After that, apply the other tips as needed. Then, there's hide mesh for remaining penetrating skin.
