By martinflashgordon - 2 Years Ago
I do simple Human RIG using template. Rigging goes well, no problem. I can animate manual without any issues/distorsions. After applying any front/side animations from CONTENT hands and feet goes apart from joints. What do I do Wrong? Attached 4 screens.
By Peter (RL) - 2 Years Ago
Hi...
Looking at your screenshots it appears the problem is because the bone joint is not fully overlapping at the wrists and ankles.
So, for correct rigging the "forearm and the hand" and the "shank and foot" must overlap each other with the bone joint pinning them together. Think of it like if you had two ribbons and wanted to pin them together. You would need to overlap the end of one ribbon with the other and put the pin through both. If you only put the pin through one of the ribbons, they will fall apart like with your character.
When I click to "strech bind" all of them on the right list are streched but on rigged character joints do not go RED. Why is that? I have done this puppet rigging from the begining using Human Motion Bone 3 F, you can see on the screen that joints there are also not connected (not RED) I can not connect joints. Or I do it wrong way.There is no button on bone editor like JOIN/WELD/etc.
How to ad locks at the end of the feet/hands/bones in CTA5 in 2D motion editor? There is no option like in old versions. How to do it?
