kmayfield (11/24/2022)
When adding DS expression clips, can in/out points be set?
Dropping a clip atop two existing DS clips deletes the clip following.
Like an NLE video editor, is it possible to drop in a clip without deleting the following clip?
Not sure if this is helpful, I've just cut the clip where I want it to end, set the playtime to the end, and insert a new DS clip. So far, that has worked.
