Edit Motion Layer is creating a single frame for that motion and not blending with the next keyframe I add
https://forum.reallusion.com/Topic526570.aspx
Print Topic | Close Window
By Vault309 - 4 Years Ago
I'm not sure if this is something I did, or if the iClone8 program is bugging out, but ive been working on multiple scenes and havent run into this issue yet. Basically when I use Edit Motion Layer and add my keyframes for movement, it wont blend and create the animation, just the single keyframe I made. No blending between point A and point B, so it just snaps from point to point. Not sure if I hit something to switch it to that, or if its a bug in the program.  If anyone could help, I would truly be grateful!
By 4u2ges - 4 Years Ago
You probably turned Auto-Extend off
https://forum.reallusion.com/uploads/images/86a5d2dd-7ec2-4827-865f-4279.jpg
