By PhiBix - 4 Years Ago
Hi there ! Who has successfully 3D printed a CC character ? How to patch the holes for 3D printing ?
I thought that Reallusion had created a function that I would not have discovered in CC3 or CC4 to optimize the mesh for printing 3D characters. But not yet. So I posted a suggestion here : https://www.reallusion.com/FeedBackTracker/Issue/3D-Printing-mesh-optimizer-for-printing-3D-characters
Here are the tests I did : Although I used the LOD functions by simplifying the mesh and merging the clothes with the character, the 3D printing software says that there are holes, making it impossible to print. - I tried with the CellBlender add-on is a Mesh Analysis tool that allows you to check that the model is manifold and correct it if it is not. No way. - I solicited a 3D printing expert who preferably uses "Netfabb" which solves a lot of problems. He also tried to fix it with "3D builder" is also a good solution to automatically make STL files compliant for 3D printing.
But nothing worked ! The character file contains too many errors and too much repair work.
Do you know anyone in the Reallusion community who has successfully 3D printed a CC character ?If so, I would like you to put me in touch with him ! ;-) Hoping it helps, Thanks :-)
