Particle dust hardly shows up without auxiliary light on. Is this normal?
https://forum.reallusion.com/Topic525859.aspx
Print Topic | Close Window
By MaxxPowr - 3 Years Ago
Hi,
Probably dumb newbie question. I have an old attic scene.
Iclone 8. Rendering in Iclone, not Iray.
Followed tutorial on creating Dust in the air. Finally got it to work.
I saved it as a custom particle and when i loaded it into my scene, I could hardly see it until I turned the Aux Light on.
My attic is dark, lit by moonlight in windows and an overhead lighbulb.
After turning the brightness of the texture emitter to max, I can see it in the seen, though very lightly. It may work.
Just trying to understand the lighting. Can it not work in a dark scene?
Thanks!
By jeffkirkland - 3 Years Ago
I’m trying to add dust particles to a scene so I was wondering if you could point me to the tutorial you found?
In terms of the dust particles, in the real world they’re only visible if light shines on them. We get to cheat things a little in 3D with self-illumination, etc but I’d expect you’d need to light them up to be seen properly in the scene.
By smallWstudio - 3 Years Ago
I've found that the "Brightness" function in the Popcorn menu will be the most help in this instance. It's a good idea to set the "Volume" amount so you are covering only the area you really need to cover with particles and not "wasting" them. Crank up the Brightness and you can see where the Particles are.
Also it's a good idea to have some "haze" in the air from Fog or a Volumetric Light effect or both so that the particles will seem more "natural".
And as Jeff mentioned in  the real world when I'm shooting a rain effect or smoky-particles, that I want to show on camera,  I "back-light" 'em so they can be seen. Front-light isn't too effective.
Hi!,
here it is https://courses.reallusion.com/home/iclone/plug-in/popcornfx-particle-effects?v=iclone-7-2-tutorial-popcornfx-super-tools-creating-floating-dust-and-god-rays
Thank you so much. I'll play with those settings.
