By ramart313 - 3 Years Ago
Hello, recently Iclone 7 has been crashing and giving me this error that says the memory could not be read. I am really not sure what this error is about and wanted to know if anyone had any ideas what it could be? Im posting a picture of the error when it comes up. Would really apreciate any help!
Thank you
By MaxxPowr - 3 Years Ago
I'm no guru, but this has happened to me. If you are on a Windows machine, try running SFC \scannow from the command prompt. You must be in administration mode to do this. It will check to make sure all you windows file are fine and not corrupted in any way, and hopefully fix them if they are.
The other thing you might try is Chkdsk to make sure your hard drives arent messed up.
I have had the scannow thing work for me, but honestly, I don't know if it had anything to do with fixing it other than just restarting the program.
Those are both good things to know about your computer, however, so it wouldn't hurt to learn them. Best of luck. If it doesn't work, contact reallusion support.
By yepkoo - 3 Years Ago
As @MaxxPowr said, your windows files may be corrupt or your drivers may be out of date. Apart from these, you may be getting this error due to insufficient memory.
For example, when using iClone and UE, I was having this problem a lot when my computer had 32gb of ram. After upgrading to 64gb ram, I never got any memory error.
