Transfer Skin Weight problem
https://forum.reallusion.com/Topic523903.aspx
Print Topic | Close Window
By Origin3D - 4 Years Ago
Hi,
I'm trying to put a cloth on a character generated with CC4 and arranged into zbrush (to erase the face). My cloth was designed with marvelous designer and exported to .obj on a single mesh. My problem is, when I try to import it as an accessory into CC4 I don't have the transfer skin weight showing...?
What I'm doing wrong ?
I've to say that if I put a CC character, the transfer skin is showing on the modify of the cloth.
https://forum.reallusion.com/uploads/images/da104fb8-2678-41b9-b42d-2f67.jpg
Thanks in advance for your help.
Regards
Fred
By 4u2ges - 4 Years Ago
That is because when you modified a character in Zbrush (changing a poly count probably), it is no longer a standard CC character and becomes a non-standard.
Non-standard characters cannot utilize CC clothing items, transfer skin weight...etc.
You may only transfer weights from body to cloth outside on CC, like in Blender (or Zbrush probably).
Tweaking/modifying weights for items (rigged to non-standard character elsewhere) is possible in CC though.
Hi 4u2ges,
Thanks for your reply.
Best regards
