By Lanzaboy - 4 Years Ago
I have just upgraded from GTX1080Ti to RTX3090. A project created in IC7 and running in IC7(latest) causes the GPU to peak at 57% (GPU-Z reading) and drops between 2-5% when the scene is idle and 15-20% when working on the scene or scrubbing the time line. The exact same project loaded in to IC8 and left static, causes the GPU to run at 85% and any movement causes the processor to max at 100% and on idle it stays there for a minute before dropping to 85%+. A new empty project in IC8 in HIGH with GI and view port GI enabled causes the GPU to run at 44%. In IC7 its 5%. I have tried this with the latest studio driver and the latest game driver (using DDU to change them). Identical results. Is this to be expected?
CPU AMD 9 5900 RAM 128GB MB ASUS X570 PRO ACE
By toystorylab - 4 Years Ago
This sounds not normal... Checked and got 2-3% GPU 2-3% CPU with a new empty project in IC8 in HIGH with GI and view port GI enabled... Be sure you have "Reduce Idle Load" ticked in "Real-Time Render Options" (Preference) When I untick that I get a boost but definitely not 44% My specs: AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz + RTX 3090 + RAM 64
