AccuRig To Iclone/CC Pipeline
https://forum.reallusion.com/Topic523101.aspx
Print Topic | Close Window
By yayettah - 4 Years Ago
Good day reallusion and thanks for providing character auto rig for all engine. Please i have some suggestions which goes as follows:
1. Add "Send to AccuRig" button into iclone and CC: Please kindly add "send to Accurig" button under modify tab into iclone and CC because of character not to lose facial rigging upon importing to AccuRig. [Check Image below for reference].
 https://forum.reallusion.com/uploads/images/0b218f08-6f49-46bb-b19a-a295.jpg
2. Add "Send to Iclone or CC" button into AccuRig: Don't forget to also add this into accurig as well so as to keep the character original texture and facial rigging upon sending back to either iclone or CC.
https://forum.reallusion.com/uploads/images/3ec9574f-a607-43a8-b274-de96.jpg
        OR
If it's possible to add "UPDATE button" so that whenever the charcter was send to AccuRig from either CC or Iclone, we could just update it in Accurig and take effect immediately in CC/ICLONE. (same as CC to Zbrush pipeline).
3. AccuRig Facial Rigging: As you add full body rigging, accurig is still missing facial rigging to make everything more perfect. I created this character in CC and send to AccuRig for better rigging, now upon sending back to iclone/CC via iVatar, the character lose the facial rigging and also the original texture. See video here>> YOUTUBE
4. More Joint: Kindly add "More joint" button incase of character that has different model method, we could just add the joint to specific area.
5. Prop Rigging: This will be more awesome if prop rigging too can be added for different props.
Thanks for your creative idea all the time.
FEEDBACK TRACKER LINK: https://www.reallusion.com/FeedBackTracker/Issue/AccuRig-to-Iclone-CC
By rcsinger29 - 4 Years Ago
I am having an issue with save iavatar with accurig.
When I save the file it will not load in iclone.
when I save fbx to another type, it cannot be converted with 3dxchange.
By Edward (RL) - 4 Years Ago
rcsinger29 (9/4/2022)
The .iAvatar export is for iClone 8 only; it does not allow to be loaded into iClone7.
Hi,
As I know, the CC4 will have its auto-rig and be more powerful.
Edward (RL) (9/5/2022)
Is there any way to get it into Iclone 7? How can I reassign the bones so I can use remap the rig in 3dX?
By dvnmedia - 3 Years Ago
Can I repeat the question is there anyway to get a rigged character from Acurig into clone 7 using 3dXchage or CC 3?
By animagic - 3 Years Ago
If you can export from AccuRIG as FBX, you should be able to import into 3DXchange.
EDIT: I wanted to verify this but currently AccuRIG crashes after the rigging has been completed.
