two actors
https://forum.reallusion.com/Topic522104.aspx
Print Topic | Close Window
By brucez_060574 - 4 Years Ago
i have two actors in stage mode that i want to interact. i can't figure out how to bring one in front or behind the other. any help is greatly appriciated
By jlittle - 4 Years Ago
All objects in Stage Mode are layered using the Z axis. Each object/actor has a Z value that places it in front of or behind other objects/actors.
Jeff
thank you for replying, however i stiil don't know how to make that happen
Select the object/actor and adjust the Z value at the top.
The higher the Z value the closer to the camera, the lower the further away.
Jeff
thank you
thx i will try that
got it to work....thanks again
Great, glad to help.
Jeff
By Peter (RL) - 4 Years Ago
brucez_060574 (8/18/2022)
You can also click on 3D View button on the top toolbar to see how the changes to the Z-Axis look. This also allows manual adjustment on all axis if required.
https://forum.reallusion.com/uploads/images/b900dfb0-6360-4f45-abf3-91f5.jpg
thank you sir
