Cannot import ActorCore FBX files into Unreal Engine 5
https://forum.reallusion.com/Topic521316.aspx
Print Topic | Close Window
By careyadrian - 4 Years Ago
Hi, I am working with a client who has a separate Reallusion account to myself. He bought a number of Animations from ActorCore he wants me to use inside Unreal Engine 5. Because we dont share accounts I cannot download these animations into Unreal Engine using his account. He has to download as separate FBX files and then send to me. When he sent me the ActorCore FBX files, I tried importing the fbx files into Unreal Engine 5 but keep getting error message below -
"Animation length 13.167 is not compatible with import frame-rate 1920 fps (sub frame 0.64), animation has to be frame-border aligned".
I am unable to import any ActorCore Animations into Unreal Engine 5. Please can someone help. I've searched online and cannot find a solution to this and we have a deadline looming.
Please can someone get back to me asap. my email is graeme@designgvr.com
By Peter (RL) - 4 Years Ago
Hi...
You need to first check that the the ActorCore motion was exported to FBX using the Unreal Target Application Preset. If it wasn't then that can cause problems.
Once you have confirmed that the FBX is using the Unreal pre-set, please follow the tutorial below which should help.
https://courses.reallusion.com/home/actorcore/unreal?v=actorcore-tutorial-for-unreal-retargeting-motion-for-ue4-characters
Thanks for the assistance, I will check that. Much appreciated
I checked with client and they did export the animation using the Unreal Engine Preset. It still doesnt import into my version of Unreal Engine. They are sending the files using Frame.io, should they maybe try sending using GoogleDrive or WeTransfer. I've also asked the client to try download the animation files from their side, and try import into a their version of Ue5, then if it works, they can save and send me that Ue5 Level. Are there any other options I could try? Also the client gave me their account details, I logged on but couldnt find in the inventory all the animations they have bought, otherwise cant I just download the animations from their account. This workflow is tedious, there must be some way to fix this as the client bought alot of animations from ActorCore and was going to keep using you guys for animations, but now is not so sure. Please help us.
I've managed to download the animations from the Clients Reallusion account. I chose the Mannequin and Unreal preset. When I try import the animation into Unreal, there is no skeleton in the import menu at the top, what skeleton must I choose, it wont let me import the animation until I've chosen a skeleton and every skeleton I choose causes error messages, but I did choose the male mannequin in ActorCore so should import with skeleton.
Now When I try download the motion clips using the clients account, it gives me an error message, please find attached. Can someone please assist us.
