What leap motion profil to use with Iclone 8?
https://forum.reallusion.com/Topic521221.aspx
Print Topic | Close Window
By Jfrog - 4 Years Ago
The hub shows version 1 but there is a version 1.1 also available. Installing v1.1 did not remove v1, so I uninstalled both version from my PC, install the profil thru the hub
again and now It shoes v1 is installed not v1.1 which is probably the one needed. Any help would be greatly appreciated.  Thank you!
