Is there a way to set iClone to use GPU
https://forum.reallusion.com/Topic521188.aspx
Print Topic | Close Window
By Kiwi-Hawk - 3 Years Ago
Is there some place I can check if iClone 7 is using my CPU or GPU please, I can't see anything in prferences
I need to set it to use the GPU, it seem's to be using %23 CPU and %0 GPU, my 11Gb 2080 Ti should surly give me better than 9.67 FPS set to medium
By animagic - 3 Years Ago
There is no specific setting in iClone to enable the GPU; it is always enabled.
A good way to find out GPU usage is with a tool like GPU-Z. It will show the GPU load during playback. If it increases then you know that iClone is using the GPU.
Thank you for the reply. I'm having a hard time understanding why my animation is such a low fps. It's a CC3 character sent direct
