Image plane opacity brightness: can you animate the change in the brightness to make the image fade away?
https://forum.reallusion.com/Topic520332.aspx
Print Topic | Close Window
By MaxxPowr - 3 Years Ago
I was wondering if it was possible to take an image layer and slowly fade it out by changing the opacity setting BRIGHTNESS, so it goes from opaque to transparent?
Thanks!
Maxx Powr
What a dolt!
I found the opacity setting which is animatable.
Doh!
By Data Juggler - 3 Years Ago
I noticed it works if I start with a black image for the opacity, I can animate the strength to have an object fade in or out, which is cool, I didn't know how to do that.
But if I start with a white image, it doesn't work the opposite way, not sure why.
Either way this could come in handy to fade things in and out.
Sometimes I stumble on to things that work. Though I'll probably forget. Good thing I save everything. Glad it helped someone.
