By worst.generation.ever.MMXX - 4 Years Ago
Has anyone figured out how to know the height of your character? If so, is there a morph slider for it?
tyvm
By Peter (RL) - 4 Years Ago
Hi...
Yes turn on the "Info" display in Preferences (CTRL+P). You can also choose to display the height in feet and inches or centimetres.
Thank you! You are a scholar and a gentleman. It looks like the only way to adjust the height is to modify the height of body parts individually. For example, chest and upper and lower leg. Am I missing a setting that will adjust the height while maintaining the relative scale of other body parts? For example, if I adjust leg and chest height, the arms will need to be adjusted as well as possibly the head or neck. Thanks.
By mark - 4 Years Ago
There is a "Body Scale" adjustment under the "Modify" tab for the avatar. In iClone.
If you have installed the FREE "Characters" pack that comes with CC4 then you should have a Character Scale A morph slider which adjusts the overall scale of the entire character.
You can find in on the Morph tab of the Modify Panel under Actor > Body > Full Body > General as shown below. Note: The other height adjustment morphs shown in the image below come from the Ultimate Morphs pack which requires separate purchase.
