What Line
https://forum.reallusion.com/Topic519939.aspx
Print Topic | Close Window
By debbie harmon - 4 Years Ago
Hello my highly esteemed friends.  I need your help once again.  What the heck is this white line and how do I get rid of it.  My avatar wants to follow it instead of the path they are connected to.  I have moved the constraint bar (I'm sure that isn't the correct term} I have tremendous problems working with paths.  I've watched the YouTube tutorials from IClone and others.  Nothing explains this white aggravating bar.  Also why does my character disappear off to the side sometimes when I connect them to a path.  They go zooming off to space with white dotted lines.  Thank you for your help.  Debbiehttps://forum.reallusion.com/uploads/images/f613c042-76f6-49ce-8db7-e03a.jpg
By mark - 4 Years Ago
Well I'll jump in and try to at least advise. Be aware it's best to post technical questions in the appropriate section of the forum. If you are using iClone 7 use the Archive iC7 section ;)
I have seen this issue from time to time in iC7. The dotted points, I believe, are keys created on the Path, that's normal. The avatar's, jumping off the path at the end, issue came about at some point in iC7's lifetime and was an issue for many myself included.  When you Release the avatar from the Path you will have the jumping issue. I believe it has been corrected in iC8.
4u2ges posted a tutorial awhile back on how to correct the jumping of the avatar for folks. I couldn't get it to work for me but I'm sure I was doing something wrong. You might try to find it in his posts.
 AS LONG AS THE AVATAR STAYS ATTACHED TO THE PATH...you're good.  When the avatar is released from the Path it will fly back to it's starting point...not good!
Thanks I'll check out that info. And I couldn't figure out where to post my question. I really don't even know how to ask it.  I searched for tutorials explaining it but couldn't find any help.  I hope IC8 does take care of this problem.
As far as I can tell it's working correctly in iC8 ;)
