program ct8 keeps shutting down
https://forum.reallusion.com/Topic519778.aspx
Print Topic | Close Window
By hmadden - 4 Years Ago
 program ct8 pipeline keeps shutting down a lot, sometimes ok then program shuts down. need help. Thanks
By Peter (RL) - 4 Years Ago
Are you using the Windows or Mac version?
windows
I also use CrazyTalk 8 on Windows and have always found it very stable.
I would advise first uninstalling CrazyTalk and giving it a clean install of the latest version just to eliminate a problem with your install. Then make sure you have Windows fully updated as well as your graphics drivers updated as these can contribute to crashes.
If the problem persists after doing the above, try to see if there is a common cause for the crashing, such as when using certain features or performing certain actions. Also does it crash when creating 2D heads, 3D heads or both? That will help narrow down the cause of the problem.
Thank you Peter
I have deleted CT8, Win 10 is up to date , The hub is installing CT8, however, It has been installing for over a hour. what can I do next?
finally installed CT8 But it still crashes
CT8 just wont stay open, just closes without notice  Help!
hmadden (8/24/2022)
Sorry to hear you are still having crashing issues.
Can you share your system specs including graphics card. Also whichever graphic card you have, please make sure you have the latest driver updates.
2.40 gigahertz Intel Core i7-4700HQ
256 kilobyte primary memory cache
1024 kilobyte secondary memory cache
6144 kilobyte tertiary memory cache
64-bit ready
Multi-core (4 total)
Hyper-threaded (8 total)SUSTeK COMPUTER INC. G750JW 1.0
System Serial Number: E2N0CY13332707F
Chassis Serial Number: E2N0CY13332707F
Enclosure Type: Notebook    2.40 gigahertz Intel Core i7-4700HQ
64-bit ready
Hyper-threaded (8 total)    NVIDIA GeForce GTX 765M [Display adapter]
Generic PnP Monitor (17.1"vis)
