HelloAnything you see in the Reallusion store, under the category of Avatar Pack/G3 Texture, is going to need the clone cloth bases or at least some other base first. Anything in the category of G3 Character, will come as a fully dressed character.
Now, two of the suits in the G3 Men in Suits Texture Pack, Volume 2 are based on the casual default cloth (Dylan cloth) or if using Iclone 3, the default casual Trey cloth that is available for download through backstage free. THerefore, you should be able to apply the textures for the two basic on casual to Dylan/Trey. In order to use the other three suits in the pack, you will only need to purchase G3 Cloth Overcoat Upper, which can be purchased through backstage for 500 points I believe, which amounts to about $5.00. The lower for the other three suits is based on the default casual.
If you need help understanding how clone cloth works, please refer to the tutorials I did which can be found at www.cloneclips.com. Here is a link to the first one. The others are easy to find by searching clone cloth. The 2nd one is specific to applying purchased imaterials to clone cloth.
http://www.cloneclips.com/video/610/Organizing-Your-CloneCloth--Tutorial
http://www.cloneclips.com/video/611/Applying-your-iMaterial-Files-in-CloneCloth--Tutorial
ADDED - If you purchased the suits Volume 1...then you also would need Trey fit lower. But as you are posting now, I am guessing it is the volume 2 you bought. Each character upper or lower is labelled with which cloth base it is based on.
